Events router
Garnet
Events router
Hi Guys,
On Thingworx 7.4 there is a very handy little widget called Events router.
This widget should be bundled in every TW version, obviously it is not.
Did someone reverseengineered that into a standalone widget?
Do you know if it will be available as one?
Tags (2)
Re: Events router
Tomas Coufal​,
I think currently the answer is No. I would suggest you to open a case with PTC support to open an enhancement request to provide it as a Standalone widget for previous versions.
Other option could be to copy the widget folder from the ThingWorx 7.4 exploded folder i.e. <ThingWorx_Tomcat_Home>\webapps\Thingworx\Common\thingworx\widgets\eventsrouter and use it to create your own widget for previous versions.
Re: Events router
Hi Tomas,
Which it's the purpose of EventsRouter? I didn't had time to give a shot on 7.4
Carles
Re: Events router
Hi Carles,
I know you would ask
Well, it brilliantly solves my issues when I wanted to route more widget's (or service's) outputs to one input parameter in one service. Which is not possible normally. I always made some workarounds (more services invoked by more buttons for an example a concat the output.). Events router let you define many inputs and their types and it has one output with trigger on change.
Needles to say this is a must have Widget.
Re: Events router
Must have for sure! I supposed it was about this, but just to confirm
Re: Events router
Dropbox - EventsRouter.zip
Standalone version of that extension. Localization tokens are replaced with hard coded text)
Enjoy
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
