Hi @atondorf,
I have used your extension and when I executed the create PDF logic, it executed without any error on the screen but I see the below error in Application log.
Could you please help me out on this.
Error {_ message='Chromium distribution 'msedge' is not found at C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Edge\Application\msedge.exe_Run "mvn exec:java -e -D exec.mainClass=com.microsoft.playwright.CLI -D exec.args="install msedge""_ name='Error_ stack='Error: Chromium distribution 'msedge' is not found at C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Edge\Application\msedge.exe_Run "mvn exec:java -e -D exec.mainClass=com.microsoft.playwright.CLI -D exec.args="install msedge""_ at executablePath (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\registry\index.js:521:13)_ at Object.executablePathOrDie (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\registry\index.js:529:43)_ at Chromium._launchProcess (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\browserType.js:174:39)_ at async Chromium._innerLaunch (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\browserType.js:105:9)_ at async Chromium._innerLaunchWithRetries (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\browserType.js:86:14)_ at async ProgressController.run (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\progress.js:92:22)_ at async Chromium.launch (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\browserType.js:63:21)_ at async BrowserTypeDispatcher.launch (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\dispatchers\browserTypeDispatcher.js:35:21)_ at async DispatcherConnection.dispatch (C:\PROGRA~2\THINGW~1\tomcat\apache-tomcat-9.0.82\temp\playwright-java-13289891056474302043\package\lib\server\dispatchers\dispatcher.js:319:22)_}
Hi @SR_10777810 ,
the extension is really early beta and just a port of an older one ... that is not supported in OpenJDK11.
But have a look at the github page I try to release updates and maybe you also can support.
In your case I am not sure, what the exact issue is, but maybe those steps may help:
Hi @SR_10777810 ,
It would be great if you can raise this issue in the Issue section in @atondorf 's GitHub project of this extension, specifically here.
This being a non-PTC third-party extension, it is not guaranteed to be supported by it creator, but at least in this way you have a better chance of reaching out to that person.
Hi @SR_10777810 ,
Hi @SR_10777810,
I wanted to follow up with you on your post to see if your question has been answered by Atondorf.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
