Steps to customize a service which export infotable data to xlsx format
Thank you for the details and information on how to do excel export.
However I'd suggest the opposite, so using Gradle instead of Ant. Any new development should be built with Gradle project, moreover, the TWX Extension for eclipse have some bugs with Ant build configs.
This is just suggestion, so both can work if correctly configured.
