Hi Friends,
I am trying to export a thing with some of the property values from one server to another using service .But the SOURCE CONTROL FUNCTIONS only gives xml format files. If there is any way to export entities in twx format using service please let me know.
Thanks in Advance
Adarsh Nair
Hey @AN_9962448 ,
Can you please share the version of ThingWorx?
Also go through the attached article How to Import/Export entities and data in ThingWorx .
Kindly revert if the given solution resolve your problem.
Regards
Bhawna
Hey @AN_9962448 ,
Regards
Bhawna
