Exporting two infotables using DataExport widget.
TIRUNL
7-Bedrock
Hi All,
I have a requirement to Export data to CSV but need two sections in imported file.
Is there a way to achieve this using DataExport Widget? Attaching screen shot for reference.
Appreciate anyone's help in advance.
Best Regards,
Lakshmi.
PaiChung
22-Sapphire I
(To:TIRUNL)
DataExport widget will export exactly what the service puts out.
So I would create a service that combines the two tables.
PaiChung
22-Sapphire I
(To:TIRUNL)
TIRUNL
7-Bedrock
(To:PaiChung)
I tried giving infotable of infotable can we do it in any other way?
PaiChung
22-Sapphire I
(To:TIRUNL)
Since you need the repeated header row, I don't think the infotable functions will help but I would just go with
var table1 = <MyFirstTable>
for each (var row in <MySecondTable>.rows) {
   table1.AddRow(row)
This may not quite work right, because you are adding a row to a table vs. a row object, so you may need  to find the proper syntax.
TIRUNL
7-Bedrock
(To:PaiChung)
Thanks, will get back to you once I try this.
TIRUNL
7-Bedrock
(To:PaiChung)
Thank you for your support, I am able to achieve with code provided with slight modification.
