the expression widget has a big problem with everything that as the word "alert" in it. I will use an expression for change the color of a panel dependent on an alert. I use the hasAlert-Service to get the alert state for a property. I bind this state to the expression parameter "hasAlert". If I write the expression
Output = hasAlert? "AlertRed" : "OkGreen";
I get the error message "You cannot use the alert function".
In the ide.js of the expression widget I saw this:
if (expression.indexOf('alert') >= 0) {
return TW.IDE.I18NController.translate('tw.expression-ide.warnings.cannot-use-alert');
I think there a better ways to prevent of using the javascript alert.
Well on your exact expression you can do a simple trick:
To ( of course you have to rename you expression parameter from hasAlert to hasAl or whatever parameter name without Alert text )
Output = (hasAl? ("Al"+"ertRed") : "OkGreen";
And yes, this javascript check it annoying and totally unusefull, neither it secures anything, should be totally removed.
I agree with that assessment. I believe there are more specific checks that can be done to eliminate improper use of JavaScript key words. This was, as you noted, the reason behind the check. For others who may see this the other key word checks are...
eval
alert
for
document
window
parent
this
while
I will bring this to the attention of the Thingworx team to see what can be updated to improve these checks.
Thank you for the post!
Adam
You cannot put an "Alert" directly into the expression, however you may create a parameter of the base type string and use it in the expression. An example would be to have a textarea feeding string values into the Expression widget parameter, and then displaying it.
This is a nice workarounds. I hope in future I don't need workarounds in twx :D
