Expression for Timestamp doesn't work in 8.4
ninja
6-Contributor
I need a Timestamp for some of my widgets but the expression does not work anymore in the updated version 8.4.
How can i evaluate the datetime in a expression ? Or do i need a service now ?
1 ACCEPTED SOLUTION
ErrHud
(To:ninja)
Try this instead :
"Output = new Date();"
and change the Output type to string.
4 REPLIES 4
PEHOWE
(To:ninja)
The expression you show in the attached PNG file is:  "new Date();"
try changing the expression to "result = new Date();"
ninja
6-Contributor
(To:PEHOWE)
Unfortunately that does'nt work either.
The Output in the Widget is "not a date..."
ErrHud
(To:ninja)
Try this instead :
ninja
6-Contributor
(To:ErrHud)
Output type string does work, thanks!
datetime would be a little bit nicer, but string works for now!
