I am using the expression widget because I want to enlarge a gadget to fullscreen;
The expression is the following
(function () { const id = widget.jqElement.closest('.mashup-popup').attr('id'); $('#'+id+'_mashup-root').css({'position':'fixed', 'top':'5%', 'left':'0', 'width':'90% !important', 'height':'100% !important'}); })()
and it is binded to a button.
Now, I would like to enlarge it with a dynamic width, e.g., the user inserts the width in pixel and gives it as a input for the expression widget.
Is it possible to bind an expression to the Expression widget?
Sorry, I found the answer.
Configure expression:
Add parameter called width: STRING
write this expression
(function () { const id = widget.jqElement.closest('.mashup-popup').attr('id'); $('#'+id+'_mashup-root').css({'position':'relative', 'width':width, 'height':'490px'}); })()
bind a input value to width
