Hi!
I have previously worked with ThingWorx Edge ADO Service and connected to Excel-spreadsheet to get some information.
Now this extension, as I understand it, is no longer available, so I can't download and install it on my new computer.
What other extensions/services can be used for the above task? That is, speaking more broadly - for remote access and collecting data from certain database (including Excel)?
Have a look at these articles:
Thanks!
You're welcome.
Hi @Mr_Henry_M ,
While the generic approach to build an extension or edge implementation can be obviously used beware of two other paths:
-the Database ThingTemplate, which allows you to connect to any JDBC compatible DB - if you have network access from ThingWorx's direction
-the Kepware's ODBC client driver, which allows you to deploy Kepware to a (Windows) computer, connect it to ThingWorx, then configuring the ODBC driver via DSN to read an excel file, etc, basically whatever is defined through DSN.https://www.kepware.com/getattachment/5db91cc5-7a93-4979-87d6-947f75eb6b94/odbc-client-manual.pdf It's 500$/year, but still, configuration only, supported, and no coding
Hi!
Ok, thank you for information.
