FAIL - Application at context path /Thingworx could not be started
agangaiah
I am trying to install ThingWorx on my machine. I was able to successfully deploy the war file but when am trying to launch ThingWorx, I am getting an error as mentioned in the subject line.
Kindly suggest.
Avinash
6 REPLIES 6
ttielebein
(To:agangaiah)
Have you checked the catalina.out or the dated catalina log file for Tomcat? Should be in $TOMCAT_HOME
agangaiah
(To:ttielebein)
Hi Tori,
I could not find the Catalina.out file in the above mentioned folder.
ttielebein
(To:agangaiah)
Oh, the log files are just named different things depending on the environment. The above logs are the ones to which I was referring. Have you tried the simple solution of restarting Tomcat? I see errors here saying listeners failed to start. The information found here seems to indicate the need to find the stack trace.
Can you tell me more about the context of the deployment? Were you upgrading or doing a fresh install? What is the environment?
Aanjan
(To:agangaiah)
Avinash, do post your catalina.log file from Tomcat_installation_path/logs folder and your ThingWorx Application logs from ThingworxStorage/logs folder.
agangaiah
(To:Aanjan)
Yes, I have posted the log files below. Please suggest.
Catalina Log:
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version:        Apache Tomcat/8.0.36
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Jun 9 2016 13:55:50 UTC
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number:         8.0.36.0
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Windows 7
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            6.1
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             C:\Program Files\Java\jre1.8.0_77
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           1.8.0_77-b03
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Oracle Corporation
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms128m
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx256m
29-Jul-2016 10:01:20.003 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\ProgramData\Oracle\Java\javapath;C:\PROGRA~1\PTC\MKSTOO~1\bin64;C:\PROGRA~1\PTC\MKSTOO~1\bin;C:\PROGRA~1\PTC\MKSTOO~1\bin\X11;C:\PROGRA~1\PTC\MKSTOO~1\mksnt;C:\Program Files\RSA SecurID Token Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\cde\tools;C:\Program Files (x86)\WebEx\Productivity Tools;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Cadence\SPB_17.0\tools\bin;C:\Cadence\SPB_17.0\tools\libutil\bin;C:\Cadence\SPB_17.0\tools\fet\bin;C:\Cadence\SPB_17.0\tools\pcb\bin;C:\Cadence\SPB_17.0\tools\specctra\bin;C:\Cadence\SPB_17.0\tools\PSpice;C:\Cadence\SPB_17.0\tools\PSpice\Library;C:\Cadence\SPB_17.0\tools\Capture;C:\Cadence\SPB_17.0\OpenAccess\bin\win32\opt;;.
29-Jul-2016 10:01:20.113 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8081"]
29-Jul-2016 10:01:20.191 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
29-Jul-2016 10:01:20.191 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
29-Jul-2016 10:01:20.206 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
29-Jul-2016 10:01:20.206 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 506 ms
29-Jul-2016 10:01:20.237 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
29-Jul-2016 10:01:20.237 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.36
29-Jul-2016 10:01:20.237 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
29-Jul-2016 10:01:20.549 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 297 ms
29-Jul-2016 10:01:20.549 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
29-Jul-2016 10:01:20.581 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 32 ms
29-Jul-2016 10:01:20.581 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
29-Jul-2016 10:01:20.596 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 15 ms
29-Jul-2016 10:01:20.596 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8081"]
29-Jul-2016 10:01:20.643 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
29-Jul-2016 10:01:20.674 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 463 ms
29-Jul-2016 10:03:00.642 INFO [localhost-startStop-2] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
29-Jul-2016 10:03:12.982 INFO [Thread-6] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8081"]
29-Jul-2016 10:03:13.053 INFO [Thread-6] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"]
29-Jul-2016 10:03:13.103 INFO [Thread-6] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina
29-Jul-2016 10:03:13.103 SEVERE [ContainerBackgroundProcessor[StandardEngine[Catalina]]] org.apache.catalina.startup.HostConfig.deployWARs Error waiting for multi-thread deployment of WAR files to complete
java.lang.InterruptedException
at java.util.concurrent.FutureTask.awaitDone(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:733)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:402)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1590)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:284)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:95)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1140)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1376)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1380)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1348)
at java.lang.Thread.run(Unknown Source)
29-Jul-2016 10:03:24.935 INFO [localhost-startStop-2] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
29-Jul-2016 10:03:45.155 SEVERE [localhost-startStop-2] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
29-Jul-2016 10:03:45.170 SEVERE [localhost-startStop-2] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
29-Jul-2016 10:03:45.186 WARNING [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [ForkJoinPool-28-worker-9] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
sun.misc.Unsafe.park(Native Method)
java.util.concurrent.ForkJoinPool.awaitWork(Unknown Source)
java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
29-Jul-2016 10:03:45.201 WARNING [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [ForkJoinPool-28-worker-2] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
29-Jul-2016 10:03:45.201 INFO [localhost-startStop-2] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 44,559 ms
29-Jul-2016 10:03:45.233 INFO [Thread-6] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8081"]
29-Jul-2016 10:03:45.264 INFO [Thread-6] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["ajp-nio-8009"]
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version:        Apache Tomcat/8.0.36
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Jun 9 2016 13:55:50 UTC
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number:         8.0.36.0
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Windows 7
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            6.1
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             C:\Program Files\Java\jre1.8.0_77
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           1.8.0_77-b03
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Oracle Corporation
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms1024m
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
29-Jul-2016 10:03:55.256 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\ProgramData\Oracle\Java\javapath;C:\PROGRA~1\PTC\MKSTOO~1\bin64;C:\PROGRA~1\PTC\MKSTOO~1\bin;C:\PROGRA~1\PTC\MKSTOO~1\bin\X11;C:\PROGRA~1\PTC\MKSTOO~1\mksnt;C:\Program Files\RSA SecurID Token Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\cde\tools;C:\Program Files (x86)\WebEx\Productivity Tools;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Cadence\SPB_17.0\tools\bin;C:\Cadence\SPB_17.0\tools\libutil\bin;C:\Cadence\SPB_17.0\tools\fet\bin;C:\Cadence\SPB_17.0\tools\pcb\bin;C:\Cadence\SPB_17.0\tools\specctra\bin;C:\Cadence\SPB_17.0\tools\PSpice;C:\Cadence\SPB_17.0\tools\PSpice\Library;C:\Cadence\SPB_17.0\tools\Capture;C:\Cadence\SPB_17.0\OpenAccess\bin\win32\opt;;.
29-Jul-2016 10:03:55.365 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8081"]
29-Jul-2016 10:03:55.427 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
29-Jul-2016 10:03:55.427 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
29-Jul-2016 10:03:55.443 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
29-Jul-2016 10:03:55.459 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 479 ms
29-Jul-2016 10:03:55.474 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
29-Jul-2016 10:03:55.474 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.36
29-Jul-2016 10:03:55.490 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
29-Jul-2016 10:03:57.986 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
29-Jul-2016 10:04:08.626 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
29-Jul-2016 10:04:08.626 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
29-Jul-2016 10:04:08.626 WARNING [localhost-startStop-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [ForkJoinPool-28-worker-9] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
29-Jul-2016 10:04:08.626 WARNING [localhost-startStop-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [ForkJoinPool-28-worker-2] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
29-Jul-2016 10:04:08.642 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 13,152 ms
29-Jul-2016 10:04:08.642 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
29-Jul-2016 10:04:08.657 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 15 ms
29-Jul-2016 10:04:08.657 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
29-Jul-2016 10:04:08.704 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 47 ms
29-Jul-2016 10:04:08.704 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
29-Jul-2016 10:04:08.720 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 16 ms
29-Jul-2016 10:04:08.720 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8081"]
29-Jul-2016 10:04:08.751 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
29-Jul-2016 10:04:08.798 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 13338 ms
29-Jul-2016 10:06:15.825 SEVERE [http-nio-8081-exec-4] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
29-Jul-2016 10:06:15.825 SEVERE [http-nio-8081-exec-4] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
29-Jul-2016 10:06:15.841 WARNING [http-nio-8081-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [ForkJoinPool-56-worker-9] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
29-Jul-2016 10:06:15.841 WARNING [http-nio-8081-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [ForkJoinPool-56-worker-2] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
TWX Application Log:
2016-07-29 10:03:25.169+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2016-07-29 10:03:25.231+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ThingWorx Version Information
2016-07-29 10:03:25.231+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2016-07-29 10:03:25.231+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] majorVersion = 7
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] minorVersion = 0
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] revision = 3
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] build = b23
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] schemaVersion = 900
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ThingWorx System Environment Settings
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] OS: Windows 7
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] OS arch: amd64
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] OS version: 6.1
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Total Processors: 8
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Default encoding: windows-1252
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JAVA vendor: Oracle Corporation
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JAVA version: 1.8.0_77
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JAVA install location: C:\Program Files\Java\jre1.8.0_77
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JVM Max Memory: 228 (MB)
2016-07-29 10:03:25.247+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] WebApp starting...
2016-07-29 10:03:25.247+0530 [L: WARN] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Please note.  Default character is set to Cp1252.  It should be [UTF-8]. Please use the VM argument [-Dfile.encoding=UTF-8] in your application server startup script
2016-07-29 10:03:25.840+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] HA mode not enabled. Initializing and starting in standalone mode.
2016-07-29 10:03:25.840+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Default Persistence Provider Name = ThingworxPersistenceProvider
2016-07-29 10:03:25.840+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Default Persistence Provider Package Name = NeoPersistenceProviderPackage
2016-07-29 10:03:28.383+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Managers...INITIALIZED
2016-07-29 10:03:28.383+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Database initialization started...
2016-07-29 10:03:28.383+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] System ownership locking started...
2016-07-29 10:03:28.383+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] System ownership locking complete
2016-07-29 10:03:39.897+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'RemoteServiceApp_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MYSQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'RemoteServiceAppDemo_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'BaiduWidgets_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'OData_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'carousel-extension'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'ProgressGauge_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'D3Tree_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Splunk_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Digi_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Eurotech_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'WebSocketTunnel_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'JTDS_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'QRCode_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'AirVantage_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Mail_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Twilio_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'GoogleWidgets_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'GoogleTranslator_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Imaging_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Xively_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Solr_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Twitter_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'D3Network_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MSSQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'SAPHana_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'CSVParser_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MQTT_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'PictureLoader_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'UniversalConverter_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'AlwaysOnSubsystem_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Queue_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'VerizonWNS_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'PTC_ExtensionPackage'  version [4.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MySQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'SAPMII_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Pushover_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'PTCOntology_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.913+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Neuron_Extension'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:03:39.929+0530 [L: WARN] [O: c.t.e.r.UIResourceCollection] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] remoteApps no longer exists for undeploy. Continuing with extension removal.
2016-07-29 10:03:39.929+0530 [L: WARN] [O: c.t.e.r.UIResourceCollection] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] tunnel/adapter.jsp no longer exists for undeploy. Continuing with extension removal.
2016-07-29 10:03:39.929+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\carousel-extension\carousel-extension.chk]: \ThingworxStorage\extensions\carousel-extension\carousel-extension.chk (The system cannot find the file specified)
2016-07-29 10:03:39.929+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [carousel-extension] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\carousel-extension\carousel-extension.chk] could not be found/read.
2016-07-29 10:03:39.929+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk]: \ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.929+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [ProgressGauge_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.929+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk]: \ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.929+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [D3Tree_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk]: \ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Digi_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk]: \ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [WebSocketTunnel_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk]: \ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [AirVantage_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk]: \ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Mail_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk]: \ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Twilio_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk]: \ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [GoogleTranslator_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.944+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk]: \ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.944+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Imaging_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk]: \ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Solr_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk]: \ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Twitter_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk]: \ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [D3Network_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk]: \ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [RemoteServiceApp_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [MSSQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk]: \ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [RemoteServiceAppDemo_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.960+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk]: \ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.960+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [SAPHana_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk]: \ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [AlwaysOnSubsystem_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk]: \ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Queue_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk]: \ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [VerizonWNS_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk]: \ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [BaiduWidgets_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [MySQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk]: \ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [PTCOntology_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.975+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk]: \ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.975+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [OData_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk]: \ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Splunk_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk]: \ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Eurotech_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk]: \ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Neuron_Extension] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk]: \ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [JTDS_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk]: \ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [QRCode_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk]: \ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [GoogleWidgets_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:39.991+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk]: \ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:39.991+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Xively_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk]: \ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [CSVParser_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk]: \ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [MQTT_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk]: \ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [PictureLoader_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk]: \ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [UniversalConverter_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk]: \ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [PTC_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk]: \ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [RadioButton_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:40.007+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:03:40.007+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [MYSQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:03:40.022+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk]: \ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:40.022+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [SAPMII_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk] could not be found/read.
2016-07-29 10:03:40.022+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk]: \ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:03:40.022+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Refreshing Extension [Pushover_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk] could not be found/read.
2016-07-29 10:03:40.319+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:40.475+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:40.740+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:40.755+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:40.771+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:40.787+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:41.348+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:41.551+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:41.567+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:41.629+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:41.972+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:41.988+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:42.144+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:42.315+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:42.331+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:03:45.155+0530 [L: INFO] [O: c.t.p.n.NeoPersistenceConnection] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] GraphDatabase...OFF
2016-07-29 10:03:45.155+0530 [L: INFO] [O: c.t.p.p.PersistenceProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Connection ThingworxPersistenceProvider, type NeoPersistenceProviderPackage stopped
2016-07-29 10:03:45.170+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] WebApp stopping:
2016-07-29 10:03:45.170+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Error getting ApplicationContext: {}null
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx Version Information
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] majorVersion = 7
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] minorVersion = 0
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] revision = 3
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] build = b23
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] schemaVersion = 900
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx System Environment Settings
2016-07-29 10:03:58.204+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS: Windows 7
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS arch: amd64
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS version: 6.1
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Total Processors: 8
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default encoding: windows-1252
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA vendor: Oracle Corporation
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA version: 1.8.0_77
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA install location: C:\Program Files\Java\jre1.8.0_77
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JVM Max Memory: 1820 (MB)
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-07-29 10:03:58.220+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp starting...
2016-07-29 10:03:58.220+0530 [L: WARN] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Please note.  Default character is set to Cp1252.  It should be [UTF-8]. Please use the VM argument [-Dfile.encoding=UTF-8] in your application server startup script
2016-07-29 10:03:58.845+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] HA mode not enabled. Initializing and starting in standalone mode.
2016-07-29 10:03:58.845+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Name = ThingworxPersistenceProvider
2016-07-29 10:03:58.845+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Package Name = NeoPersistenceProviderPackage
2016-07-29 10:04:00.623+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Managers...INITIALIZED
2016-07-29 10:04:00.623+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Database initialization started...
2016-07-29 10:04:00.623+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking started...
2016-07-29 10:04:00.701+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking complete
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'RemoteServiceApp_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MYSQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'RemoteServiceAppDemo_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'BaiduWidgets_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'OData_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'carousel-extension'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'ProgressGauge_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'D3Tree_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Splunk_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Digi_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Eurotech_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'WebSocketTunnel_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'JTDS_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'QRCode_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'AirVantage_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.551+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Mail_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Twilio_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'GoogleWidgets_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'GoogleTranslator_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Imaging_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Xively_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Solr_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Twitter_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'D3Network_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MSSQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'SAPHana_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'CSVParser_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MQTT_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'PictureLoader_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'UniversalConverter_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'AlwaysOnSubsystem_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Queue_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'VerizonWNS_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'PTC_ExtensionPackage'  version [4.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'MySQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'SAPMII_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Pushover_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'PTCOntology_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.567+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-21-worker-9] The extension  'Neuron_Extension'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:04:06.692+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\carousel-extension\carousel-extension.chk]: \ThingworxStorage\extensions\carousel-extension\carousel-extension.chk (The system cannot find the file specified)
2016-07-29 10:04:06.692+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [carousel-extension] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\carousel-extension\carousel-extension.chk] could not be found/read.
2016-07-29 10:04:06.692+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk]: \ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.692+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [ProgressGauge_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.692+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk]: \ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.692+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [D3Tree_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.692+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk]: \ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.692+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Digi_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.692+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk]: \ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [WebSocketTunnel_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk]: \ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [AirVantage_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk]: \ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Mail_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk]: \ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Twilio_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk]: \ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [GoogleTranslator_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk]: \ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Imaging_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk]: \ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Solr_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk]: \ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.707+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Twitter_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.707+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk]: \ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [D3Network_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk]: \ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [RemoteServiceApp_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [MSSQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk]: \ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [RemoteServiceAppDemo_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk]: \ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [SAPHana_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk]: \ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [AlwaysOnSubsystem_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk]: \ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Queue_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.723+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk]: \ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.723+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [VerizonWNS_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk]: \ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [BaiduWidgets_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [MySQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk]: \ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [PTCOntology_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk]: \ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [OData_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk]: \ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Splunk_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk]: \ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Eurotech_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.738+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk]: \ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk (The system cannot find the file specified)
2016-07-29 10:04:06.738+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Neuron_Extension] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk]: \ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [JTDS_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk]: \ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [QRCode_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk]: \ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [GoogleWidgets_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk]: \ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Xively_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk]: \ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [CSVParser_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk]: \ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [MQTT_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.754+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk]: \ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.754+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [PictureLoader_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.770+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk]: \ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.770+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [UniversalConverter_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.770+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk]: \ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.770+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [PTC_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.770+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk]: \ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.770+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [RadioButton_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.770+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:04:06.770+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [MYSQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:04:06.770+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk]: \ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.770+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [SAPMII_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.770+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk]: \ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:04:06.770+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Refreshing Extension [Pushover_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk] could not be found/read.
2016-07-29 10:04:06.910+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:06.988+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.113+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.128+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.144+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.347+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.440+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.472+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.643+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.659+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.721+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:07.784+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:04:08.626+0530 [L: INFO] [O: c.t.p.n.NeoPersistenceConnection] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] GraphDatabase...OFF
2016-07-29 10:04:08.626+0530 [L: INFO] [O: c.t.p.p.PersistenceProvider] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Connection ThingworxPersistenceProvider, type NeoPersistenceProviderPackage stopped
2016-07-29 10:04:08.626+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp stopping:
2016-07-29 10:04:08.626+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Error getting ApplicationContext: {}null
2016-07-29 10:06:06.291+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] ========================================
2016-07-29 10:06:06.291+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] ThingWorx Version Information
2016-07-29 10:06:06.291+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] majorVersion = 7
2016-07-29 10:06:06.291+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] minorVersion = 0
2016-07-29 10:06:06.291+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] revision = 3
2016-07-29 10:06:06.291+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] build = b23
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] schemaVersion = 900
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] ========================================
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] ThingWorx System Environment Settings
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] OS: Windows 7
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] OS arch: amd64
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] OS version: 6.1
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Total Processors: 8
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Default encoding: windows-1252
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] JAVA vendor: Oracle Corporation
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] JAVA version: 1.8.0_77
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] JAVA install location: C:\Program Files\Java\jre1.8.0_77
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] JVM Max Memory: 1820 (MB)
2016-07-29 10:06:06.307+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] WebApp starting...
2016-07-29 10:06:06.307+0530 [L: WARN] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Please note.  Default character is set to Cp1252.  It should be [UTF-8]. Please use the VM argument [-Dfile.encoding=UTF-8] in your application server startup script
2016-07-29 10:06:06.697+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] HA mode not enabled. Initializing and starting in standalone mode.
2016-07-29 10:06:06.697+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Default Persistence Provider Name = ThingworxPersistenceProvider
2016-07-29 10:06:06.697+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Default Persistence Provider Package Name = NeoPersistenceProviderPackage
2016-07-29 10:06:08.319+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Managers...INITIALIZED
2016-07-29 10:06:08.319+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Database initialization started...
2016-07-29 10:06:08.319+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] System ownership locking started...
2016-07-29 10:06:08.335+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] System ownership locking complete
2016-07-29 10:06:13.766+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'RemoteServiceApp_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'MYSQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'RemoteServiceAppDemo_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'BaiduWidgets_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'OData_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'carousel-extension'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'ProgressGauge_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'D3Tree_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Splunk_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Digi_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Eurotech_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'WebSocketTunnel_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'JTDS_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'QRCode_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'AirVantage_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Mail_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Twilio_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'GoogleWidgets_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'GoogleTranslator_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Imaging_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Xively_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Solr_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Twitter_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'D3Network_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'MSSQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'SAPHana_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'CSVParser_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'MQTT_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'PictureLoader_ExtensionPackage'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'UniversalConverter_Extensions'  version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'AlwaysOnSubsystem_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.781+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Queue_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'VerizonWNS_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'PTC_ExtensionPackage'  version [4.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'MySQL_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'SAPMII_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Pushover_Extensions'  version [3.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'PTCOntology_ExtensionPackage'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.797+0530 [L: WARN] [O: c.t.p.c.u.ExtensionInfoUtilities] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-49-worker-9] The extension  'Neuron_Extension'  version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
2016-07-29 10:06:13.922+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\carousel-extension\carousel-extension.chk]: \ThingworxStorage\extensions\carousel-extension\carousel-extension.chk (The system cannot find the file specified)
2016-07-29 10:06:13.922+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [carousel-extension] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\carousel-extension\carousel-extension.chk] could not be found/read.
2016-07-29 10:06:13.922+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk]: \ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.922+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [ProgressGauge_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\ProgressGauge_ExtensionPackage\ProgressGauge_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.922+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk]: \ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.922+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [D3Tree_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\D3Tree_ExtensionPackage\D3Tree_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.922+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk]: \ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.922+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Digi_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Digi_Extensions\Digi_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.922+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk]: \ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.922+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [WebSocketTunnel_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\WebSocketTunnel_ExtensionPackage\WebSocketTunnel_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk]: \ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [AirVantage_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\AirVantage_Extensions\AirVantage_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk]: \ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Mail_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Mail_Extensions\Mail_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk]: \ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Twilio_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Twilio_Extensions\Twilio_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk]: \ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [GoogleTranslator_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\GoogleTranslator_Extensions\GoogleTranslator_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk]: \ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Imaging_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Imaging_Extensions\Imaging_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk]: \ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Solr_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Solr_Extensions\Solr_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk]: \ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Twitter_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Twitter_Extensions\Twitter_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.937+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk]: \ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.937+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [D3Network_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\D3Network_ExtensionPackage\D3Network_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk]: \ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [RemoteServiceApp_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RemoteServiceApp_ExtensionPackage\RemoteServiceApp_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [MSSQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MSSQL_ExtensionPackage\MSSQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk]: \ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [RemoteServiceAppDemo_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RemoteServiceAppDemo_ExtensionPackage\RemoteServiceAppDemo_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk]: \ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [SAPHana_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\SAPHana_ExtensionPackage\SAPHana_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk]: \ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [AlwaysOnSubsystem_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\AlwaysOnSubsystem_ExtensionPackage\AlwaysOnSubsystem_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk]: \ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Queue_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Queue_ExtensionPackage\Queue_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk]: \ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.953+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [VerizonWNS_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\VerizonWNS_Extensions\VerizonWNS_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.953+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk]: \ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [BaiduWidgets_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\BaiduWidgets_ExtensionPackage\BaiduWidgets_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [MySQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MySQL_ExtensionPackage\MySQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk]: \ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [PTCOntology_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PTCOntology_ExtensionPackage\PTCOntology_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk]: \ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [OData_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\OData_Extensions\OData_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk]: \ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Splunk_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Splunk_Extensions\Splunk_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk]: \ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Eurotech_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Eurotech_Extensions\Eurotech_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk]: \ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Neuron_Extension] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Neuron_Extension\Neuron_Extension.chk] could not be found/read.
2016-07-29 10:06:13.969+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk]: \ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.969+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [JTDS_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\JTDS_ExtensionPackage\JTDS_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk]: \ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [QRCode_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\QRCode_Extensions\QRCode_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk]: \ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [GoogleWidgets_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\GoogleWidgets_ExtensionPackage\GoogleWidgets_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk]: \ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Xively_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Xively_Extensions\Xively_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk]: \ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [CSVParser_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\CSVParser_Extensions\CSVParser_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk]: \ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [MQTT_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MQTT_Extensions\MQTT_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk]: \ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [PictureLoader_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PictureLoader_ExtensionPackage\PictureLoader_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk]: \ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [UniversalConverter_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\UniversalConverter_Extensions\UniversalConverter_Extensions.chk] could not be found/read.
2016-07-29 10:06:13.984+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk]: \ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:13.984+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [PTC_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\PTC_ExtensionPackage\PTC_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:14.000+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk]: \ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:14.000+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [RadioButton_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\RadioButton_ExtensionPackage\RadioButton_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:14.000+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk]: \ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk (The system cannot find the file specified)
2016-07-29 10:06:14.000+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [MYSQL_ExtensionPackage] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\MYSQL_ExtensionPackage\MYSQL_ExtensionPackage.chk] could not be found/read.
2016-07-29 10:06:14.000+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk]: \ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:14.000+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [SAPMII_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\SAPMII_Extensions\SAPMII_Extensions.chk] could not be found/read.
2016-07-29 10:06:14.000+0530 [L: WARN] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Could not find and/or read Extension checksum file [C:\ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk]: \ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk (The system cannot find the file specified)
2016-07-29 10:06:14.000+0530 [L: INFO] [O: c.t.p.d.RootEntityDocumentModelProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Refreshing Extension [Pushover_Extensions] from persistence layer because its checksum file [C:\ThingworxStorage\extensions\Pushover_Extensions\Pushover_Extensions.chk] could not be found/read.
2016-07-29 10:06:14.140+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.218+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.343+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.359+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.374+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.577+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.671+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.686+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.717+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.873+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.889+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:14.951+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:15.014+0530 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2016-07-29 10:06:15.825+0530 [L: INFO] [O: c.t.p.n.NeoPersistenceConnection] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] GraphDatabase...OFF
2016-07-29 10:06:15.825+0530 [L: INFO] [O: c.t.p.p.PersistenceProvider] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Connection ThingworxPersistenceProvider, type NeoPersistenceProviderPackage stopped
2016-07-29 10:06:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] WebApp stopping:
2016-07-29 10:06:15.841+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8081-exec-4] Error getting ApplicationContext: {}null
Aanjan
(To:agangaiah)
Do you have an existing ThingworxStorage and ThingworxBackupStorage folder preset? If so, can you move (or rename) them and try deploying again? This will deploy a vanilla (clean) build of ThingWorx.
