Facing an issue while installing thingworx 8.4 on top of sql
Sheetal_sable
     I am installing thingworx 8.4 on top of sql server 2017. After Installation when I go to Composer, message showing as "503 Service Unavailable". So I have checked the Application Log showing message as "message: Unable to initialize and start system: Connections could not be acquired from the underlying database!".
     For reference I have attached Application log, platform-setting.json.
We are following the document for installation as https://support.ptc.com/WCMS/files/172634/en/Getting_Started_with_MS_SQL_Server_and_ThingWorx_1.pdf.
Could you please help to resolve this.
Sheetal
slangley
(To:Sheetal_sable)
Hi @Sheetal_sable.
Did you download the jdbc driver?  I have attached it here.
Unzip it first, then drop it into <tomcat_home>\lib, then restart Tomcat.
--Sharon
6 REPLIES 6
Please take a look at this article: Debug ThingWorx Platform and MSSQL database connectivity
The steps provided in the article might help with the resolution.
Best regards,
Rajesh.
hi @Rajesh_Sayana ,
  I followed all the steps as provided here 'Please take a look at this article: Debug ThingWorx Platform and MSSQL database connectivity' .Also tried validation techniques provided by community still not fixed the problem.But still i am facing issue (attached screenshot of it) and Application log and platform-setting is attached.
I have queries:
1. which jdbc driver is used for sql server 2017.
2. Is attached platform-settings.json file correct.
3. need to set any environment variables?
Can you Please provide detailed procedure from start to end sequentially for installing thingworx 8.4 on top of SQL 2017.
I have also searched for customer care details but no success, could you please provide the customer care details as well
Please help me regarding this.
Make sure %JAVA_HOME%\bin   and    %JRE_HOME%\bin   are available in environment path variable.
hi,
Thanks for reply.
%JAVA_HOME%\bin and %JRE_HOME%\bin are available in environment path variale. But still facing an issue.
slangley
(To:Sheetal_sable)
Hi @Sheetal_sable.
--Sharon
slangley
(To:slangley)
Hi @Sheetal_sable.
If the previous reply allowed you to solve your issue, please mark the appropriate response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
