Facing problem in MQTT setup. Please help
amitworx
I am trying to create a sample mqtt based temperature sensor mashup.
However the values are not getting updated.
I have found that while sending data to Thingworx from the mosquitto, it always get a socket error.
I tried to restart the service many times, I can always see on mosquitto prompt that the subscribe request is received.
Also one more confusing thing is that thingowrx always shows isConnected = true and correct lastConnection time.
I am using tomcat 7 and thingworx 6.5.0-b460 war that comes along with training material.
Kindly help me resolve the problem
I have also seen that there is no way to set QoS in the configuration. It may be unrelated, but still don't think that always setting QoS = 0 is a good idea.
Many Thanks!
Amit
What MQTT Extension are you using? From Market Place or support.ptc.com Software download?
Can you please check the application log when you saved your MQTT thing and send the log output?
