Failed to run github extension while exporting
AP_9587236
I clicked on this export button in mashup - GitBackup.Main.Mashup. Execution failed and errors were observed.
->Invalid service name: ExportProjectEntities
->Invalid service name: GetConfiguration
The configuration given to the thing is -
Iam using thingworx 9.2 version. What is the problem here?
3 REPLIES 3
slangley
23-Emerald II
(To:AP_9587236)
Hi @AP_9587236.
What version of the GitBackup extension are you using?  Check the github site for possibly locating an extension that would be closer in compatibility to the ThingWorx version you're running.
We noticed you had posted similar questions on github.  You can drill in to each one to see a response and further instructions for resolving.
--Sharon
These extensions only i imported.
slangley
23-Emerald II
(To:slangley)
Hi @AP_9587236.
If you're not sure which version you installed, you may want to remove it and install the latest version available.
Did you check the responses to the questions you posted on github?  That will be the best resource for finding the answers you need.
--Sharon
