Failed to transfer a file to a virtual directory
htran-21
Thingworx WSEMS process is running as LocalSystem user, the target folder is accessible, but it is failed to move a file in Thingworx staging folder into the designated folder due to Error 17.
Does anyone know what the error means? Any help would be greatly appreciated!
My Bests,
Hung Tran
2 REPLIES 2
mnarang
(To:htran-21)
Can you please attach complete EMS logs by putting the logger level in DEBUG/TRACE in config.json ?It's difficult to crack this from this screenshot .
you can also put verbose= true in ws_connection segment of config.json along with the above setting .
Thanks ,
Mukul Narang
htran-21
(To:mnarang)
Hi Mukul Narang,
I have just had a chance to duplicate it. However, the TRACE log is not actually explaining what happened.
[DEBUG] 2020-06-05 01:37:22,779 serviceHandler: Handling service MoveFile for thing IPU_100346 locally
[DEBUG] 2020-06-05 01:37:22,782 SDK: getRealPath: Real path for IPU_100346:__staging__\IPU_100346.Folder1.zk.bat.part\ = r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part
[DEBUG] 2020-06-05 01:37:22,785 SDK: getRealPath: Real path for IPU_100346:\Folder1\zk.bat\ = c:\Folder1\zk.bat
[DEBUG] 2020-06-05 01:37:22,787 SDK: getRealPath: Real path for IPU_100346:__staging__\IPU_100346.Folder1.zk.bat.part\ = r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part
[TRACE] 2020-06-05 01:37:22,787 SDK: twFileManager_GetOpenFile: Looking for tid: NA, realpath: r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part.
[TRACE] 2020-06-05 01:37:22,788 SDK: twFileManager_GetOpenFile: Compare to tid: d4851164-6d93-4ca5-ab6e-284ca2d15207, realpath: r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part.
[TRACE] 2020-06-05 01:37:22,789 SDK: twFileManager_GetOpenFile: Found Open file r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part\
[TRACE] 2020-06-05 01:37:22,790 SDK: twFileManager_GetOpenFile: Returning r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part
[DEBUG] 2020-06-05 01:37:22,792 SDK: twMoveFile: Moving file __staging__\IPU_100346.Folder1.zk.bat.part to \Folder1\zk.bat
[ERROR] 2020-06-05 01:37:22,793 SDK: twMoveFile: Error moving file __staging__\IPU_100346.Folder1.zk.bat.part to \Folder1\zk.bat. Error: 17
[TRACE] 2020-06-05 01:37:22,794 SDK: twOfflineMsgStore_Flush: Creating buffer for reading offline message store. size = 8220
[DEBUG] 2020-06-05 01:37:22,795 SDK: twMessage_Delete:  Deleting RESPONSE Message: 0
[DEBUG] 2020-06-05 01:37:22,795 SDK: twWs_SendMessage: Sent 17 bytes using 1 frames.
[TRACE] 2020-06-05 01:37:22,796 SDK: twMessage_Send: Message with RequestId 177937 sent successfully
[DEBUG] 2020-06-05 01:37:22,797 SDK: twMessage_Delete:  Deleting RESPONSE Message: 177937
[DEBUG] 2020-06-05 01:37:22,797 SDK: twMessage_Delete:  Deleting REQUEST Message: 177937
[TRACE] 2020-06-05 01:37:22,798 SDK: twTlsClient_Read: Read: 2, Asked for: 2
[TRACE] 2020-06-05 01:37:22,801 SDK: twWs_Receive: Read 2 bytes into header buffer
[TRACE] 2020-06-05 01:37:22,803 SDK: twWs_Receive: Got Header: Body length = 1
[TRACE] 2020-06-05 01:37:22,806 SDK: twTlsClient_Read: Read: 1, Asked for: 1
[TRACE] 2020-06-05 01:37:22,809 SDK: twWs_Receive: Read 1 bytes into Frame buffer
[TRACE] 2020-06-05 01:37:22,812 SDK: twWs_Receive: Received Ping
[TRACE] 2020-06-05 01:37:22,814 SDK: msgHandlerOnPing: Received Ping.  Data:
[TRACE] 2020-06-05 01:37:23, 19 SDK: twTlsClient_Read: Read: 2, Asked for: 2
[TRACE] 2020-06-05 01:37:23, 20 SDK: twWs_Receive: Read 2 bytes into header buffer
[TRACE] 2020-06-05 01:37:23, 45 SDK: twTlsClient_Read: Read: 2, Asked for: 2
[TRACE] 2020-06-05 01:37:23, 46 SDK: twWs_Receive: Read 2 bytes into header buffer
[TRACE] 2020-06-05 01:37:23, 46 SDK: twWs_Receive: Got 2 byte length. 0x8 0x17
[TRACE] 2020-06-05 01:37:23, 47 SDK: twWs_Receive: Got Header: Body length = 2071
[TRACE] 2020-06-05 01:37:23, 47 SDK: twTlsClient_Read: Read: 2071, Asked for: 2071
[TRACE] 2020-06-05 01:37:23, 52 SDK: twWs_Receive: Read 2071 bytes into Frame buffer
[TRACE] 2020-06-05 01:37:23, 54 SDK: twWs_Receive: Received Binary Message in Single Frame
[TRACE] 2020-06-05 01:37:23, 57 SDK: twInfoTableRow_CreateFromStream: Marker is empty. No more rows in stream
[TRACE] 2020-06-05 01:37:23, 60 SDK: twInfoTableRow_CreateFromStream: Marker is empty. No more rows in stream
[TRACE] 2020-06-05 01:37:23, 63 SDK: msgHandlerOnBinaryMessage: Inserted message onto queue. ID: 177938, Type: 1, Queue Total: 1
[TRACE] 2020-06-05 01:37:23, 65 SDK: twMessageHandler_msgHandlerTask: Processing Incoming Message Queue, Queue Total: 1
[TRACE] 2020-06-05 01:37:23, 67 SDK: twMessageHandler_msgHandlerTask: Removing Message ID: 177938 from Incoming Messages Queue
[TRACE] 2020-06-05 01:37:23, 67 SDK: twMessageHandler_msgHandlerTask: Received Binary Message ID: 177938, Queue Total: 0
[TRACE] 2020-06-05 01:37:23, 67 SDK: handleMessage: Received Request Message ID: 177938
[DEBUG] 2020-06-05 01:37:23, 68 serviceHandler: Handling service CancelFileTransfer for thing IPU_100346 locally
[DEBUG] 2020-06-05 01:37:23, 68 SDK: twFinishFileTransfer: Finishing file transfer d4851164-6d93-4ca5-ab6e-284ca2d15207
[TRACE] 2020-06-05 01:37:23, 68 SDK: twFileManager_GetOpenFile: Looking for tid: d4851164-6d93-4ca5-ab6e-284ca2d15207, realpath: NA.
[TRACE] 2020-06-05 01:37:23, 69 SDK: twFileManager_GetOpenFile: Compare to tid: d4851164-6d93-4ca5-ab6e-284ca2d15207, realpath: r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part.
[TRACE] 2020-06-05 01:37:23, 69 SDK: twFileManager_GetOpenFile: Found Open file r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part\
[TRACE] 2020-06-05 01:37:23, 70 SDK: twFileManager_GetOpenFile: Returning r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part
[TRACE] 2020-06-05 01:37:23, 70 SDK: adjustPath:
Original Path: \Folder1\zk.bat.
AdjustedPath: __staging__\IPU_100346.Folder1.zk.bat.part
[DEBUG] 2020-06-05 01:37:23, 71 SDK: getRealPath: Real path for IPU_100346:__staging__\IPU_100346.Folder1.zk.bat.part\ = r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part
[TRACE] 2020-06-05 01:37:23, 71 SDK: twFileManager_GetOpenFile: Looking for tid: NA, realpath: r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part.
[TRACE] 2020-06-05 01:37:23, 71 SDK: twFileManager_GetOpenFile: Compare to tid: d4851164-6d93-4ca5-ab6e-284ca2d15207, realpath: r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part.
[TRACE] 2020-06-05 01:37:23, 72 SDK: twFileManager_GetOpenFile: Found Open file r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part\
[TRACE] 2020-06-05 01:37:23, 74 SDK: twFileManager_GetOpenFile: Returning r:\Build\Thingworx.MicroServer\sendfolder\IPU_100346.Folder1.zk.bat.part
[FORCE] 2020-06-05 01:37:23, 78 SDK: twFinishFileTransfer: ERROR.  File: \Folder1\zk.bat
[AUDIT] 2020-06-05 01:37:23, 81 :
FILE TRANSFER NOTIFICATION:
Source: FileRepo_IPU_100346:\zk.bat/zk.bat
Destination: IPU_100346:\Folder1\zk.bat/zk.bat
StartTime: 2020-06-05 01:37:21,505
EndTime: 2020-06-05 01:37:22,260
Duration: 755 msec
User: tranh
State: ERROR
Message: Error occurred during transfer.
Transfer ID: d4851164-6d93-4ca5-ab6e-284ca2d15207
[TRACE] 2020-06-05 01:37:23, 83 SDK: twFileManager_CloseFile: Closing file: IPU_100346.Folder1.zk.bat.part
My Bests,
Hung Tran
