Hi @all
My ThingWorx version is 6.5.6 and i wonder when i upgrade to 6.5 the FieldSet widget that i used on responsive as well as
static layouts its title is cutoff i tried on test mashup for static and responsive mashup but it didn't work , anyone who have experienced
this issue ?
Nilesh,
I've seen this issue prior, but not with the OOTB version of ThingWorx. Have you imported any additional extensions into your ThingWorx instance? There may be a fieldset widget overriding the OOTB version and causing issues with one of the widget's CSS attributes.
Meghan
Thanks Meghan Hollenbach for the reply , yes i do have custom chart extension for bar,time series etcc additional to that we have in Thingworx
i will look for workaround pushing and popping out some extension if that may be the problem .
