I have a test case as following
var testfile = 'test.txt'
me.CreateTextFile({ path: testfile, data: 'Hello, world!', overwrite: true }) // WORKING
me.CreateTextFile({ path: testfile, data: 'Good morning!', overwrite: true }) // WORKING
me.LoadText({ path: testfile }) // WORKING
me.DeleteFile({ path: testfile }) // NO ERROR, but the file isn't deleted
me.CreateTextFile({ path: testfile, data: 'Bye bye!', overwrite: true }) // ERROR
ERROR: Wrapped java.lang.Exception: Unable to Create File [test.txt] Cause: Unable to Create File [test.txt]
My Bests,
Hung Tran
FYI, this is a known bug fixed by TW-36598 on Apr 3 2019 and applied for all Thingworx versions 7.4.19+
My Bests,
Hung Tran
Will it delete the file if you don't load it?
When you load the file, temporary locking occurs and until it's released, it won't delete.
What version of ThingWorx are you on?
Hi posipova,
Yes, the file would be deleted if that's not loaded yet.
No, that's not a kind of temporarily locking, I believe that's a bug in code of reading a file content.
It is Thingworx 7.4.1-b62
My Bests,
Hung Tran
My Bests,
Hung Tran
