File Upload widget
jensc
File Upload widget
Is there any way to limit the number of simultaneous files uploaded in the widget properties?
I realize I could do some limitations by not using the automatic upload and counting the files using the "FileNames" propery.
However I kind of like the automatic upload feature so if possible I'd like to keep it.
Any ideas are highly welcome!
Jens
Thanks for the detailed explanation.
Set MaxNumberOfFiles value to 1
I have couple of queries here,
  • simultaneous files uploaded in the widget - By multiple users or single user?
  • automatic upload feature - Do you want upload from client system (browser) to Thingworx server?
Sorry, I was perhaps a bit unclear:
#1: It is possible to select and upload multiple files all at once:
Where I would like it to be limited to only one file at once.
#2: The automatic upload feature is that once you have selected one or more files (or dragged them to the widget), it will automatically start the upload to the selected repository:
So basically to "avoid" uploading more than one file at a time (per user), I would have to remove the possibility of automatic upload and check if there are more than one file name in:
But I feel like this would confuse users as this doesn't stop them from actually selecting multiple files.
At least I haven't found any property to change it to only one file per upload, but perhaps I have just missed it.
Jens
