Fileupload widget issue on ThingWorx 9.3 running on iPad / iPhone
MA8731174
Would you please give me any update about this issue. I am having a same issue at the moment and my thingworx version is also 9.3.
Important info: When i connect mouse with ipad with cable and click browse button it works. When i touch i click on browse with my finger. It does not work. If you need any further information for debugging purposes just let me know about it.
Thank you!
Rocko
(To:MA8731174)
The answer of Vlad is still valid in all points. We can't tell if a ticket was created with support. That would be a question to the original thread poster.
But 9.3 is out of support so you might want to update first and see if the issue persists. If it is a bug, then a fix won't be backported to 9.3 anyways. Probably something in jquery library and taps vs clicks.
You could try the tap-to-click setting as a workaround. https://www.idownloadblog.com/2020/04/22/tap-to-click-ipad-tutorial/
Rocko
(To:MA8731174)
Thank you and yes this problem is still in this version 9.3 as i have examine it with ptc. We are planning to now update the version to 9.7.
