Filter SQL data while using multiSelect Combobox
Muthu_chithira
8-Gravel
Hi All,
Based on selection of combobox, have to filter data. For that i wrote sql query as:
             SELECT col1  FROM table where col1 in ([[CheckInfo]])
        Input :- CheckInfo='value1','value2'
But filter is not happening
But if i give Input as :- CheckInfo='value1'
It fetching data.
How to give input for multivalues
Hello @Muthu_chithira,
Depending on the underlying RDBMS, you might be able to split the string in SQL, e.g. STRING_SPLIT for T-SQL.
Constantine
1 REPLY 1
Constantine
