Finding the number of fields in a datashape
Janicen
Hi all
In relation to this article: https://community.ptc.com/t5/IoT-Tips/DataShape-Nuances-Tips-Tricks/ta-p/817583?search-action-id=107104588871&search-result-uid=817583,
How can one find the number of fields in a datashape?
I have tried this:
let result = infotableData.DataShapeName.fields.length;
However this is the error I keep getting:  TypeError: Cannot read property "fields" from undefined.
Thank you.
Arun_C
(To:Janicen)
Hi @Janicen ,
Im not sure why "let result = infotableData.DataShapeName.fields.length;" is not working.
But you can try this below code to find the field count from infotable.
let dataShapeFields = infotableData.dataShape.fields;
var fieldCount = 0;
for (let fieldName in dataShapeFields) {
fieldCount++;
result = fieldCount;
Thanks & Regards,
Arun C
5 REPLIES 5
Arun_C
(To:Janicen)
Hi @Janicen ,
var fieldCount = 0;
fieldCount++;
Thanks & Regards,
Arun C
Hi @Janicen  & @Arun_C
You can avoid the loop by below code
let dataShapeFields = infoTable.dataShape.fields;
var result = Object.keys(dataShapeFields).length;
/VR
Janicen
(To:Arun_C)
In addition to my question above, 1. Is it possible to delete a datashape using a service/snippet?  2. Can I add a field definition to a datashape dynamically.
PS this data shape is not linked to a table, therefore something like this: infotableData.AddField({ name: ""New Field, baseType: "NUMBER" }); will not work as it will only store the "New Field" temporarily when executing the service and not in the actually datashape entity.
I have created  a datashape dynamically using a service:
let params2 = {
name: "DB_name" /* STRING */,//Change name
description: "undefined" /* STRING */,
projectName: undefined /* PROJECTNAME */,
fields: My_Fields /* INFOTABLE */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateDataShape(params2);
In certain scenarios I would like to add or remove fields from this datashape. If this is not possible then I would rather delete the entire DS and recreate it but this time the new field will be include in the "My_Fields" table.
Thank you.
Arun_C
(To:Janicen)
Hi @Janicen ,
You can add or remove the fields based on the below 'Datashape' services  of AddFieldDefinition  and RemoveFieldDefinition
DataShapes["<<YOURDATASHAPENAME>>"].AddFieldDefinition({
	name: undefined /* STRING */,
	description: undefined /* STRING {"defaultValue":""} */,
	type: undefined /* BASETYPENAME */,
	ordinal: undefined /* INTEGER {"defaultValue":0} */,
	primaryKey: undefined /* BOOLEAN {"defaultValue":false} */,
	dataShape: undefined /* DATASHAPENAME */
 DataShapes["<<YOURDATASHAPENAME>>"].RemoveFieldDefinition({
If you want to delete the entire datashape entity please find this article - https://www.ptc.com/en/support/article/CS237875
Thanks & Regards,
Arun C
Janicen
(To:Arun_C)
Very helpful snippets: remove and add field definitions worked.
Thank you.
