For Line chart, show ist series only as Line without marker in ThingWorx 9.2
RK_0705
11-Garnet
Hi Team,
I have the use case to show one series as Line only  and other series as marker only in Line chart.
Since ThingWorx 9.2 is not having stroke property to hide the marker from series 1 and hidemarkers property will hide the markers from all series. (In ThingWorx 9.1 there was present this stroke property so it was achievable earlier)
How can we show ist series only as Line without marker and second series as marker only in ThingWorx 9.2
Thanks in advance.
13 REPLIES 13
sbt
(To:RK_0705)
I have the same issue. but i am not sure how you have achieved in 9.1. i don't see any stroke property though.
Thanks.
RK_0705
11-Garnet
(To:sbt)
@sbt
In ThingWorx 9.1 under style definitions you will get series1,series2 .. etc styles for separate series.
For the series you want to hide marker from the line just make the fill & stroke property of Marker for that series as transparent color (#FFFFFF00)
But this stroke property of Marker got removed in ThingWorx 9.2
sbt
(To:RK_0705)
I tried your option now but looks somewhat like below where its not getting transparent instead a  white spot.
am i doing something wrong??
sbt
(To:RK_0705)
Got it , I think the code should have been "#ffffff00".
RK_0705
11-Garnet
(To:sbt)
yes corrected in my last comment.
slangley
23-Emerald II
(To:RK_0705)
Hi @RK_0705.
Which patch level of 9.2 are you on?  For 9.2.3, we can see the stroke options under Style Properties.
--Sharon
@slangley We are using TWX 9.2.1.
slangley
23-Emerald II
(To:RK_0705)
Hi @RK_0705.
Here's what I see under 9.2.1:
Are you expecting to see something different?
--Sharon
@slangley
As you can see there is no 'stroke' property under under Marker.
There are only two i.e. fill and stroke-width.
Earlier there were three including 'stroke' also in TWX 9.1.
slangley
23-Emerald II
(To:RK_0705)
Hi @RK_0705
Is this what you're looking for?
This was achieved with these options:
If this isn't what you are looking for, please provide a rendering of how it appeared in 9.1.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @RK_0705.
I was waiting for the release of 9.3 to see if the missing option had been re-added.  I just confirmed it's not there, so I will be opening a case to request it.
--Sharon
I have also faced the same issue, this would be a great feature to have as thingworx 9.2 is not supporting a different series type for each series
sbt
(To:slangley)
Do you have any updates in this regard because i don't see the option available in 9.3.1 too. Or an alternative way to achieve the same.
