HI All,
I want to use in Thingworx a widget Creo view for to see a a mechanica part cretaed by Creo (extension *.psz, *.pvs.*.edx, *.ed, *.ol).
Where I found the plugin for by browser ?
Please, can someone help me?
Meny Thanks
Dimitri
You do need to have Creo installed in order to use the widget.
You may download the following extension which includes Creoview widget ThingWorx IoT Marketplace
You do have to have Creo installed in your system (express minimum).
Hi Polina,
I have installed all the extension found in Thingworx Market place for Creo and Whindchill.
The Thingworx page return a following message
An installation of PTC Creo View is required in order to use this Widget.
Can you help me ?
BR
Dimitri
Hi Polina,
yes it is correct I don't need Creo installed.
But I think to need a Creo Pluging for my browser. Where I download It ?
BR
Dimitri
Dimitri, I apologize for the miscommunication. You *do* need to have it installed.
Hi Polina,
is needed to install Creo to use the widget Creo View in Thingworx or is needed a plugin ?
BR
Dimitri
Yes, you do need to install Crew (at least the express version) to use the widget.
Hi Polina,
Many Thanks.
Anoter question , is the Creo expresso vision free ?
BR
Dimitri
Hi Polina,
Many Thanks
I try it and I will send you a message.
BR
Dimitri
I install the Creo View Lite 3.0 and I can open my stp file in it. Then I import the Creo View Widget, and set the url to ProductToView, then the mashup shows me "An installation of PTC Creo View is required in order to use this Widget."
How can I solve this problem?
I install the Creo View Express in local computer, install the ThingWorx in VM. I use the local computer to open the Mashup by url, but it reports "An installation of PTC Creo View is required in order to use this Widget." Are the Creo View Express or the ThingWorx installed in the same computer? Do you meet this problem?
