Foundation_Tutorial_Services.xml
dnpermadhy-2
Regular Member
Hi All,
I need file "Foundation_Tutorial_Services.xml" for Thingworx 8.0.
Any have it?
Thanks.
Rgrds
Deddy
Tags (1)
3 REPLIES 3
Re: Foundation_Tutorial_Services.xml
Hi Deddy,
Could you elaborate what module are you working with exactly and what's the intent?
Hi Sushant,
There I worked to import data entities,but I can NOT to import of sample XML file.
Sorry I somehow missed your reply, if you are still running into this same issue could you retry with Use Default Persistence Provider and Ignore Subsystems options selected?
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
