FromJSON() returns empty infotable
SOLVED
Highlighted
Level 1
I have a JSON which is NOT empty and I want to convert it to infotable with FromJSON() but it returns me an empty infotable.
Here a part of my code :
var jsont = { dataShape: { fieldDefinitions : {} }, rows: [] };
    var cal1;
    if (type == "Temperature") {
    jsont.dataShape.fieldDefinitions['Temperature'] = { name: 'Temperature', baseType: 'NUMBER' };
    else if (type == "EFS") {
        jsont.dataShape.fieldDefinitions['Mesure1'] = { name: 'Mesure1', baseType: 'NUMBER' };
        jsont.dataShape.fieldDefinitions['Mesure2'] = { name: 'Mesure2', baseType: 'NUMBER' };
    /**if (row.Batterie) {
            result.dataShape.fieldDefinitions['Batterie'] = { name: 'Batterie', baseType: 'NUMBER' };
  jsont.dataShape.fieldDefinitions['Timestamp'] = { name: 'Timestamp', baseType: 'DATETIME' };
    for (var x = 0; x < tableLength; x++) {
        var row = datas.rows;
        // CustomPropertiesHistory entry object
        newEntry = new Object();
            newEntry.Temperature = 0;
            newEntry.Temperature = row.Temperature; // NUMBER
            //cal1 = row.Mesure1 * 10 * 0.001;
            cal1 = row.Mesure1 / 10;
            newEntry.Mesure1 = 0;
            if (cal1) {
            newEntry.Mesure1 = cal1; // NUMBER
            newEntry.Mesure2 = 0;
        if (row.Batterie) {
            newEntry.Batterie = 0;
            newEntry.Batterie = row.Batterie; // NUMBER
        newEntry.Timestamp = row.timestamp; // DATETIME - isPrimaryKey = true
        //newEntry.Timestamp = dateAddMilliseconds(row.timestamp, -3600000); // DATETIME - isPrimaryKey = true
        jsont = newEntry;
    logger.error(jsont[3].Temperature);
    //var result = jsont;
    var params = {
  json: jsont /* JSON */
  // result: INFOTABLE
  var result = Resources["InfoTableFunctions"].FromJSON(params);
    logger.error(result[3].Temperature);
At line 48 logger returns me the value but at line 59 it returns me an error :
Wrapped java.lang.IndexOutOfBoundsException: Index: 3, Size: 0 Cause: Index: 3, Size: 0
I also noticed that if I end my script with result containing the JSON, so var result = datashape ... Put new entries in result, ... logger returns the value asked but if I test my service, the table will appear empty.
Tags (2)
1 ACCEPTED SOLUTION
Re: FromJSON() returns empty infotable
Can you please post the JSON you are trying to convert to an InfoTable?
Edit: Actually, looking at this, I made a few changes to your code:
jsont.rows = [];
    var cal1;
            if (cal1) {
        if (row.Batterie) {
        jsont.rows = newEntry;
    logger.error(jsont.rows[3].Temperature);
    var params = {
2 REPLIES 2
jsont.rows = [];
    var cal1;
            if (cal1) {
        if (row.Batterie) {
    var params = {
The JSON is generated dynamically on the code. But your changes solved my issue !
Many thanks !
