I have a JSON which is NOT empty and I want to convert it to infotable with FromJSON() but it returns me an empty infotable.
Here a part of my code :
var jsont = { dataShape: { fieldDefinitions : {} }, rows: [] };
var cal1;
if (type == "Temperature") {
jsont.dataShape.fieldDefinitions['Temperature'] = { name: 'Temperature', baseType: 'NUMBER' };
else if (type == "EFS") {
jsont.dataShape.fieldDefinitions['Mesure1'] = { name: 'Mesure1', baseType: 'NUMBER' };
jsont.dataShape.fieldDefinitions['Mesure2'] = { name: 'Mesure2', baseType: 'NUMBER' };
/**if (row.Batterie) {
result.dataShape.fieldDefinitions['Batterie'] = { name: 'Batterie', baseType: 'NUMBER' };
jsont.dataShape.fieldDefinitions['Timestamp'] = { name: 'Timestamp', baseType: 'DATETIME' };
for (var x = 0; x < tableLength; x++) {
var row = datas.rows
; // CustomPropertiesHistory entry object
newEntry = new Object();
newEntry.Temperature = 0;
newEntry.Temperature = row.Temperature; // NUMBER
//cal1 = row.Mesure1 * 10 * 0.001;
cal1 = row.Mesure1 / 10;
newEntry.Mesure1 = 0;
if (cal1) {
newEntry.Mesure1 = cal1; // NUMBER
newEntry.Mesure2 = 0;
if (row.Batterie) {
newEntry.Batterie = 0;
newEntry.Batterie = row.Batterie; // NUMBER
newEntry.Timestamp = row.timestamp; // DATETIME - isPrimaryKey = true
//newEntry.Timestamp = dateAddMilliseconds(row.timestamp, -3600000); // DATETIME - isPrimaryKey = true
jsont
= newEntry; }
logger.error(jsont[3].Temperature);
//var result = jsont;
var params = {
json: jsont /* JSON */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].FromJSON(params);
logger.error(result[3].Temperature);
At line 48 logger returns me the value but at line 59 it returns me an error :
Wrapped java.lang.IndexOutOfBoundsException: Index: 3, Size: 0 Cause: Index: 3, Size: 0
I also noticed that if I end my script with result containing the JSON, so var result = datashape ... Put new entries in result, ... logger returns the value asked but if I test my service, the table will appear empty.
Can you please post the JSON you are trying to convert to an InfoTable?
Edit: Actually, looking at this, I made a few changes to your code:
jsont.rows = [];
var cal1;
if (cal1) {
if (row.Batterie) {
jsont.rows
= newEntry; }
logger.error(jsont.rows[3].Temperature);
var params = {
jsont.rows = [];
var cal1;
if (cal1) {
if (row.Batterie) {
jsont.rows
= newEntry; }
var params = {
The JSON is generated dynamically on the code. But your changes solved my issue !
Many thanks !
