Funny Bug? within MSSQL Select
bot1q
Hey guys,
can someone explain me that "bug?" which is growing from 8.2 --> current version.
SELECT MAX(VALUE_TIME)
FROM MyEpicTableDataAnonym
result = 2019-10.12 .....
and
SELECT MAX(VALUE_TIME) AS EPICMAXTIME
result = 2019-10.03 ..
results me in two different answers ...
12 REPLIES 12
bot1q
(To:bot1q)
No ideas?
eliotlandrum
(To:bot1q)
I'm afraid you'll need to provide more context to understand what you're asking.
bot1q
(To:eliotlandrum)
If i do an SELECT without "AS MyFanceValue" I receive  a different result then when i use "AS" in the select statement
bot1q
(To:eliotlandrum)
SELECT MAX(VALUE_TIME)    // THIS IS ANONYM
and
SELECT MAX(VALUE_TIME) AS EPICMAXTIME //THIS IS NOT ANONYM
results me in two different answers on the same data ...
eliotlandrum
(To:bot1q)
Can you show some of the data and the type of field that VALUE_TIME is?
bot1q
(To:eliotlandrum)
That is data independent..
It is a MS -SQL Database and the type is Datatime
eliotlandrum
(To:bot1q)
I would like to be able to help you, but I really need more information than you're providing. Screenshots of table configuration and sample data would be extremely helpful. You haven't provided enough information for me to be able to replicate this on my own system. The result you showed is not a SQL datetime format (it has a period after the month, which is not standard and doesn't show a time), so you're modifying the results before sharing them here.
bot1q
(To:eliotlandrum)
SELECT  MAX(TIME)
FROM
[X].[Y].DATA
Where type of  DATA = datetypeoffset(7) // Database is MSSQL
Example of data: 2018-11-07 00:10:00.0000000 +01:00
Hello @bot1q,
Wondering whether it's a ThingWorx issue, or MS SQL... Does it work correctly when you execute the same in another SQL client, e.g. sqlcmd?
/ Constantine
Vilia (my company) | GitHub | LinkedIn
bot1q
(To:Constantine)
Directly in MSSQL query it works Well.
Could also be a JDBC driver bug, make sure you use the latest version.
slangley
(To:bot1q)
Hi @bot1q.
Please let us know if you found a solution for your issue.  If one of the previous posts helped to solve it, please mark the appropriate one as the Accepted Solution.  Otherwise, please post the solution you found and mark that as the Accepted Solution for the benefit of others with the same issue.
--Sharon
