GUID Purpose and Uses
vtielebein
7-Bedrock
Hello all,
The GUID property type allows for any string assignment as there are different formats that GUID can take. I am therefore wondering what distinguishes the GUID property type from the String property type. Are there different services or widgets that work only with GUIDs?
Thanks!
Tori
It's exactly the same, and don't use GUID as in 6.5 there's a bug which prevents on using it correctly.
Even I had faced the same problem while using GUID base type and could not differentiate it with String base type.
You can refer to few observations mentioned in below link. But response still awaiting from thingworx side.
Working with GUID Base type in Thingworx
It would be better if you use String base type.
