Gadget reference
GM_9528891
11-Garnet
Gadget reference
Hi everybody!
Is there a way to get a unique reference of a gadget (as there are THINGNAME and MASHUPNAME etc)?
I am trying to use gadgets as a parameter of an infotable and I don't know how.
Giorgia
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:GM_9528891)
Can't really help you with this, but obviously somewhere in the persistence provider this exist.
So I would run the Developer tools and see what services are called when the dashboard and gadgets load to see what the system uses to retrieve dashboard configuration.
You should be able to utilize those services.
PaiChung
22-Sapphire I
(To:GM_9528891)
slangley
23-Emerald II
(To:GM_9528891)
Hi @GM_9528891.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
