Gateway time-out error with implementing shape.
Garnet
I am getting an error, when I am giving a shape to existing template, so that it can inherit the properties of shape. But the following error arises.
2 REPLIES 2
Highlighted
Re: Gateway time-out error with implementing shape.
Have you tried the same while authenticated as an Administrator user?
Highlighted
Hi @rajee
If the response provided by @posipova helped to solve your issue, please mark it as the Accepted Solution for the benefit of others with the same issue.
Thank you for using our community!
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
