Get a count of the rows which has specific value
KT_10107318
8-Gravel
Hi all, i have a infotable which is returned from Store procedure. The infotable has a column which returns 0 and 1. Is there any way to get the count of the rows which has value 1. Thanks in advance
I think of 2 ways...
  • The 1st one with do the query on infotable with 0 or 1 and get a row count.
var query = {
   "filters":{
      "type": "EQ",
      "fieldName": "<field_name>",
      "value": 1
let params = {
	t: <infotable data>/* INFOTABLE */,
	query: query /* QUERY */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].Query(params);
  • The 2nd one do aggregate function with group by columns
    let params = {
    	columns: <any unique field> /* STRING */,
    	aggregates: 'COUNT'/* STRING */,
    	groupByColumns: <0 or 1 field> /* STRING */
    let result = Resources["InfoTableFunctions"].Aggregate(params);​
var query = {
   "filters":{
      "type": "EQ",
      "value": 1
let params = {
    let params = {
Thanks it works
DanZ
(To:KT_10107318)
The approach of Sathishkumar_C is totally fine. But as a short alternative the following is also possible:
const result = infotable.rows.toArray().filter(row => row.valueColumn === 1).length;
infotable --> your infotable variable
valueColumn --> your column name with the value
I will try this too
