Get monitoring and log data via rest API
MM_9628870
Is there any REST API or java sdk provided by ThingWorx  to get monitoring and logging data ?
PaiChung
22-Sapphire I
(To:MM_9628870)
Hopefully this helps
https://www.ptc.com/en/support/article/CS329281?&language=en&posno=2&q=thingworx%20rest%20api%20post&source=search
The ServiceDefinitions should show you the parameters available, those you would construct and submit as a JSON in the body.
10 REPLIES 10
PaiChung
22-Sapphire I
(To:MM_9628870)
You can just call the available services associated with the logs.
MM_9628870
(To:PaiChung)
ok let me try and get back to you.  Thanks!
MM_9628870
(To:PaiChung)
Hey @PaiChung   Can you tell me which api to call since there is no GET api to get the service details
PaiChung
22-Sapphire I
(To:MM_9628870)
All of these will be POST types
See for example: <server>/Thingworx/Logs/ApplicationLog/Services/QueryLogEntries
MM_9628870
(To:PaiChung)
Can you give a link to the documentation for this API?
PaiChung
22-Sapphire I
(To:MM_9628870)
Basically works like any other Thingworx service.
You can also use this to see the parameters
<Server>/Thingworx/Logs/ApplicationLog/ServiceDefinitions/QueryLogEntries
or start from here and drill in <server>/Thingworx/Logs/ (this is a regular GET)
MM_9628870
(To:PaiChung)
what should be the request body for <Server>/Thingworx/Logs/ApplicationLog/ServiceDefinitions/QueryLogEntries since it is a POST api
PaiChung
22-Sapphire I
(To:MM_9628870)
MM_9628870
(To:PaiChung)
Thanks!!
Will try and get back to you
MM_9628870
(To:PaiChung)
Thanks @PaiChung !! It works!! marking your answer as a solution
