Get style information of style definition
drichter
It it possible to get style information of a style definition entity in a service?
5 REPLIES 5
supandey
(To:drichter)
Hi @drichter I don't see any OOTB service available for this, would it be possible for you to share short comment on what the use case is?
Digging a bit with the services, if you use GetDifferencesAsJSON service you can get difference styling between a base style and the given one, you get something like this where you can get the styling, crappy but it can work:
Sorry it's the old value, your code should look something like this:
// -- where styleName contains the Style Name for which you want to recover style content
var data =  StyleDefinitions[styleName].GetDifferencesAsJSON({ otherEntity:"DefaultMashupStyle" });
var result =data.rows[data.rows.length-1].difference.rows[0].oldValue.value;
drichter
(To:CarlesColl)
Thanks, I will try this later if I had more time.
drichter
(To:supandey)
I use the grid advanced with a non specified infotable as input. To use this without defined datashape you need to specified the columns and the styles via json. To have the same styles in every view I want to use the style definition entity.
