Getting errors when trying the telnet command to check network connection from thingworx
KV_10974131
I am trying to check the network connection with another server from thingworx , but when i try to run the telnet from command prompt it gives me following error.
'telnet' is not recognized as an internal or external command, operable program or batch file
Hello @KV_10974131
I assume it is not enabled from your windows feature . You have to go to   search and search for turn windows feature on and off in this you have to further search for telnet client and check the check box for telnet client. Once you see windows completed the requested changes you can close and verify the telnet on command prompt.
Let me know if you still face any issues.
Hello @KV_10974131
