Getting org.jboss.resteasy.spi.UnhandledException: java.lang.LinkageError: Failed to link com/thingworx/communications/client/ConnectedThingClient
mdhakeph
I am getting org.jboss.resteasy.spi.UnhandledException: java.lang.LinkageError: Failed to link com/thingworx/communications/client/ConnectedThingClient (Module "deployment.Windchill.ear:main" from Service Module Loader)     at org.jboss.resteasy.core.ExceptionHandler.handleApplicationException(ExceptionHandler.java) while connecting through JAVA Edge SDK to ThingWorx server, any idea what is going wrong? I have created App Key through ThingWorx composer and using it in ClientConfigurator which is used for ConnectedThingClient. Any help in this regard would be helpful.
Thanks!
Meghana
Did you double check that you a referencing all of the correct jar files that you need to be?
