Unable to Compile SteamSensor - SSL defines
gseq
7-Bedrock
I'm running the latest CSDK - 1.3.1-957. I switched the compile flags to my compiler and am having a hard time resolving the following referenced. Note that compile is all ok. It is a link time error. I've checked all the include files as well as made sure that CONFIG_SSL_ENABLE_CLIENT is set to 1 under thirdparty/axTLS.
#define CONFIG_SSL_ENABLE_CLIENT 1
This is using the SteamSensor example.
/opt/uClinux/bfin-uclinux/lib/gcc/bfin-uclinux/4.1.2/../../../../bfin-uclinux/bin/ld.real: Warning: gc-sections option ignored
../../../build/obj/gcc-linux-bfin/debug/libTw.a(tls1.o): In function `ssl_ctx_free':
../src/thirdParty/axTLS/ssl/tls1.c:206: undefined reference to `_remove_ca_certs'
../../../build/obj/gcc-linux-bfin/debug/libTw.a(x509.o): In function `sig_verify':
../src/thirdParty/axTLS/ssl/x509.c:276: undefined reference to `_bi_import'
../src/thirdParty/axTLS/ssl/x509.c:280: undefined reference to `_bi_mod_power2'
../src/thirdParty/axTLS/ssl/x509.c:282: undefined reference to `_bi_export'
../src/thirdParty/axTLS/ssl/x509.c:297: undefined reference to `_bi_import'
../src/thirdParty/axTLS/ssl/x509.c:302: undefined reference to `_bi_clear_cache'
../../../build/obj/gcc-linux-bfin/debug/libTw.a(x509.o): In function `x509_verify':
../src/thirdParty/axTLS/ssl/x509.c:415: undefined reference to `_bi_clone'
../src/thirdParty/axTLS/ssl/x509.c:419: undefined reference to `_bi_compare'
gseq
7-Bedrock
(To:gseq)
Tracing further.. it is because CONFIG_SSL_CERT_VERIFICATION is not defined. However it is defined in crypto.h through CONFIG_SSL_ENABLE_CLIENT.
/* enable features based on a 'super-set' capbaility. */
#if defined(CONFIG_SSL_FULL_MODE)
#define CONFIG_SSL_CERT_VERIFICATION
#elif defined(CONFIG_SSL_ENABLE_CLIENT)
#endif
Any help is appreciated.
jcanosa
(To:gseq)
The bi_XXX functions are in the AxTLS library in  crypto/bigint.c, are you sure you included that in the Makefile you created for your uClinux port?
gseq
7-Bedrock
(To:jcanosa)
Thanks for your help.
The issue was a compilation problem. Our app code is in g++, while TW in gcc. It compiles well now, but I have a BSD socket issue now in another ticket.
