Downloaded the "Git Backup Extension 2.0" from the following :
But I get the following error when Importing:
Extension Exception: A write error occurred while copying package for processing.
The TWX version I am using is ThingWorx 9.2.4-b254.
@slangley @c_lowy @PaiChung @CarlesColl @VladimirRosu
Shashi.
I appreciate the direct mention, but for any support related to the GitBackup extension, please open an issue here https://github.com/PTCInc/thingworx-gitbackup-extension/issues .
The GitBackup extension is not a PTC supported product, hence the ask.
Also, before doing that, did you try to load any other extension to see if that's not maybe the root cause?
Hi @VladimirRosu ,
Thanks for the quick response, yes other extensions are importing except the Github Backup Extension.
Shashi.
