Hello community,
sorry for english, i'm using Google Translate (Czech to English)..
I wonder how is it with Google Map Widget and the limit of 25,000 impressions a day? Do I assume that this limitation also applies to the ThingWorx widget? If so, how can I solve this problem?
Thank you
Hi Dominik, key included with the google map widget is for development/test purpose probably that's why you are seeing the limit. Therefore if you expect to have much larger number of calls to the widget you'll need to buy the commercial license key from Google and this needs to be included in the widget.
