Google Map Widget not working - SteamSensorWithFileTransfer
rhodson
Using ThingWorx 6.6
I have a remote device running the SteamSensorWithFileTransfer example code.
I can verify that the device connects and transmits location information - I can see the location being sent from a trace on the device, and if I use a table or label widget I see the values correctly appear.
From Trace
   BaseType:    STRING  Value: Location Length: 8
   BaseType:   VARIANT  Value:    BaseType:  LOCATION   Value: Long: 43.213502, Lat: -77.842957, Elev: 0.000000
   BaseType:  DATETIME  Value: 85294362
   BaseType:    STRING  Value: GOOD     Length: 4
( The location is from the hardcoded example ) I slightly tweaked how the location changes per sample, as the default example was getting out of bounds very quickly. So my values change every sample but only a little.
The problem is that the Google Map Extension I installed doesn't seem to display the location correctly.
Here is a screen shot - as you can see the location appears in Antarctica- but if you look closely you can see my Lat and Lon are no where near there.
I based my google map widget settings off the tutorial - so I have ShowSelection Marker checked and my Location is linked to the SelectedLocation data item in the widget
Any suggestions?
ibanham
(To:rhodson)
Hi
If I search in Google maps with the co-ordinates shown as location in your grid, it goes to the same location in Antarctica.
If I reverse the co-ordinates, I end up near Rochester NY.....
Ian
ibanham
(To:rhodson)
Hi
Ian
rhodson
(To:ibanham)
I missed that - thank you. Of course it was something simple.
I double checked and the bug is in the example src for the c-sdk
properties.Location.longitude = 43.221462;
properties.Location.latitude = -77.850917;
Is there a preferred method to report defects back to ThingWorx, I have found a handful sofar
