Google Maps Widget Default Marker Style
drieder
Hello everyone,
I would like to prevent the Marker Image from changing when e.g Selecting a marker.
In my case I have multiple different Objects with different avatars/markers on my map. And I would like to make them selectable. But as far as I see, the "selected Marker" style is used when I select an Object. But I would like to keep the appearance of the Object.
Also when removing the selected Marker style it still uses the default blue marker when selecting an object.
Any Ideas how to solve that problem?
Thank you very much.
Best Regards,
Dominik
PaiChung
22-Sapphire I
(To:drieder)
This has been an issue with the Google Map widget for a long time, I am not skilled enough to be able to exactly give you a resolution.
first thought is a custom widget (and I think there might be a way to turn ability to select off, but you seem to want to be able to select still)
Not sure if it is possible by overwriting the CSS otherwise.
PaiChung
22-Sapphire I
(To:drieder)
That is unfortunate :(
Another option would be to define a selection marker for each object, but it seems you can only define one selection marker for the whole widget
slangley
(To:drieder)
Hi @drieder.
If the response provided by @PaiChung answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
