Google Maps Widget
gwoilerrauscher
Google Maps Widget
Hallo,
does anyone know how I can show a route in the google maps widget?
Or where I could find any documentation on this subject.
I am able to show a static location in the map, but I cannot show a route.
Should I create a thing to be my route. It should be a infotable with the localization points only? How do I show this on the map?
Thanks in advance!
Gustavo, you would need to bind data to the RouteData setting in the GoogleMap Widget properties. Once you have data set, you can check ShowRoute to display them. If you just want to show the path, you can check ShowPathBetweenMarkers.
Thanks for the reply,
I tried creating a data set (it was an Infotable with three locations) and it really show this route on the map.
Now I want to update this infotable with the "realtime" location of another thing I have (My cellphone).
I can already display the location of the phone on the map, but I am unable to show the path followed so far.
I could use some help, thanks!
Are the values logged to a Stream or ValueStream? You would need location history to display multiple points.
What is routedata? and how to create routedata? thanks!
