Hi everyone, I want to use google map widget and I follow this post Display Geolocation Data Using Google Maps Part 1 when I finished Step.1 then in step.2 i create a mashup and want to add google map widget but the google widget did not appear in Widget tab.
I tried to remove and reinstall the extension but the google widget still not appear.
Can anyone tell me how to solve it ? Thanks a lot!
Similar issue:
Similar issue:
OMG, it's really help! Thanks a lot!
I can keep doing the practice.
You're welcome.
