Google maps widget not working on second tab
sponomarenko-3
2-Explorer
Hi, I have a very simple mashup - it has Tabs responsive widget  in ThingWorx 6.6.
First tab contains single googlemaps widget.
Second tab contains panel and a fixed-sized googlemaps widget.
In runtime second map is not displayed. (Map images are not added into the control).
If I do not use panel and use responsive map widget on the second tab - everything is ok.
Can anybody have a workaround?
4 REPLIES 4
Sergey, that looks like it is a bug. I tried testing with a layout where one side is responsive, and the other side with panels and Google Map on both of them it rendered fine. But when using tabs, and switching to the one with a panel, it does not render. If you view your Mashup and open dev tools (F12) and switch to the network tab, you can see that the Map does not get called when you switch tabs. Would it be possible for you to open a support case for this?
ttielebein
(To:Aanjan)
Aanjan
(To:ttielebein)
That would not be the same. The google map itself is not rendering if placed on a panel in a different tab.
OK, I'll open the case.
