GoogleMap Marker icon problem
flucciarini
I have a problem with the GoogleMap Widget. When the widget shows more markers on the map only the selected item has the correct icon; the others show a wrong icon (see screenshot below).
I find the problem.
MarkerField properties is setted to avatar, I resetted the properties and now work fine.
Thanks to all for support.
8 REPLIES 8
posipova
20-Turquoise
(To:flucciarini)
What is your version of Thingworx, tomcat, java, and operating system?
Have you tried in a different browser?
Server
Red Hat Enterprise Linux Server release 7.1
ThingWorx Composer 7.3.1-b39
Tomcat 8.0.33
Java "1.8.0_92"
Client
Windows 7
Tested on Google Chrome ver. 56.... (64 bit) and Firefox ver. 47.0.1
Fabrizo,
You can find information on how to work with multiple icons here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS235093
Has anyone else seen this behavior in their Google widgets?
Jeremy, I have not faced this issue on my local instance.
I find the problem.
Hi Fabrizio Lucciarini​,
Could you please mark your answer as correct and also mark helpful comments to let other members know this Thread has a solution and can be benefited.
My Google Map don't have that problem when showing multiple icons, so please show us the screenshot of your list of styles ( as shown below), and MarkerFormatting if you have put anything inside.
Another question, was it always shown like this (use Gear icons as markers) ? Or maybe when you have fewer items, every marker appears normally, while as the number of the items increase, not selected markers suddenly became gears?
Please reset your Marker style property for the Google Map.
Secondly, could you please check that if you are using state formatting; if yes; please review it and make sure it does not set the Gear icon.
Do let us know in case of any queries.
I hope it helps.
Ankit Gupta
