Got an error while creating Alert.
Sathishkumar_C
Hi All,
I am trying to add alert to the property with a service.
Got an error like Error executing service test. Message :: Alert Type [Above] is not valid - See Script Error Log for more details. How to resolve this issue?
I followed same code mentioned here.
// Create the Attributes Infotable for AddOrUpdateAlert call
var params = {
	infoTableName: "alertAttr" /* STRING */
var attrs = Resources["InfoTableFunctions"].CreateInfoTable(params);
// Define the fields required by an Above type Alert for an INTEGER field (not the values!)
// limit - Minimum value at which the alert will trigger.
var field = new Object();
field.name = "limit";
field.baseType = 'INTEGER';
attrs.AddField(field);
// limitInclusive - Is the condition Greater than (>) or Greater than or equal (>=)?
field.name = "limitInclusive";
field.baseType = 'BOOLEAN';
// Define the new Alert values and add the row to the table.
var row = new Object();
row.limit = 5;					// Alert will trigger when field >=5
row.limitInclusive = true;		// Alert includes 5
attrs.AddRow(row);
// Call the AddOrUpdateAlert Service
var params = {
	alertType: "Above" /* STRING */,
	alertName: "MyAlert" /* STRING */,
	property: "MyIntProperty" /* STRING */,
	attributes: attrs /* INFOTABLE */,
   	priority: 1 /* INTEGER */,
	persistent: true /* BOOLEAN */,
	enabled: true /* BOOLEAN */
me.AddOrUpdateAlert(params);
5 REPLIES 5
Hello.
The code you pasted in is indeed the same as the example in the Help Center; what does the Script Error Log referenced by the error message say?
-- Craig A.
Yes. I am replicating the same scenario. i am getting an error, Error executing service test. Message :: Alert Type [Above] is not valid - See Script Error Log for more details.
Hello all,
We are also facing same issue in Thingworx 8.3.0 which is working fine in Thingworx 8.2
VR
CRArko
(To:Velkumar)
Hi, all.
Is there anything in the Script Error Log that indicates what the problem might be?
-- Craig A.
sarathi
(To:Sathishkumar_C)
Hi
May Be "MyIntProperty" on your thing either String or some other Base type
