I am facing a weird behavior with grid.
I am population grid with an infotable, I call it 'data_IT' . 'data_IT' is a property of a thing 'Thing_A'
In the mashup, I associate the 'data_IT' to the grid using the service getproperties. and i check 'Automatically update values when...' so, when a row is updated, it's replicated automatically in my mashup.
Everything works fine until I added a new field of type 'Image'. The automatic update stop working !
When i remove the image field, it's works fine again!!
Is there any solution for this bheavior ?
Thank you for you help
Thingworx version is 9.5.1 . I use the default widget grid.
I found an other alternative. I use ImageLink instead of Image. The images are stored in my repository.
It solve the problem
Which version of ThingWorx are you running?
Which grid widget are you using? Have you tried a different one to see if the behavior is consistent?
--Sharon
Hi @AliBenBelgacem Thanks for sharing the alternative solution, mark it as the solution for future reference.
