Question :
Hello all , I have developed a Mashup in v9.1 which contains a grid widget. I have migrated the application to v9.3
The grid widget's rows are now getting sorted after service invoke completion which returns the data to the grid .
Thanks in advance for your support.
Hi @RK_10025077
Is it possible you changed the sort order under configure properties? It may be caching the last change.
There are 2 sort options to check. One is accessed by selecting the cog in the properties panel for the widget. The other can be found in the upper-left corner of the widget --select Configure Grid Columns.
Regards.
--Sharon
Hi @RK_10025077
Regards.
--Sharon
