The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I would like to trigger an HTTP request from ThingWorx to an external HTTP endpoint in order to notify a data change.
I defined a subscription associated to my Thing but do not know how to fill the "Script" section at Susbscription definition.
I've already tried to use a typical XMLHttpRequest object with no luck.
Please, could you provide some guidance?
Thank you,
Luis
In the ContentLoader resource there are services that help you do HTTP calls.
Thanks Pai, I really apreciate it!
Any tutorial, or doc where I could find more about it?
Thanks in advance!
You can start with the online doc.
Perfect!
That was what I was looking for.
Best regards
Luis
