Having multiple Y axis in line Chart
MK_9986318
Line chart has one x and one y axis but I want one more Y axis in Line chart. Please let me know How can we add secondary Y-axis in Line chart widget.
Hi @MK_9986318 ,
If you are using  ThingWorx Platform 9.2.0" -> Widget Enhancements --> Chart widgets under the Themable category are now enhanced with the following features: ---> "Reference lines—Added support for horizontal and vertical reference lines on charts. You can use widget properties and bindings to add and configure the value, label, and orientation of each reference line on a chart."
Also I am attaching the URL for further reference:
Introduction to line chart widget extension
Kindly respond if you ned further help.
Bhawna
already there.
Hi @MK_9986318 ,
Kindly let me know if the shared information is helpful for you.
 Please validate it and if satisfied, please mark the Accepted Solution for the benefit of others with the same issue.
Bhawna
