Hi, Can we import the application developed in Thingworx 7.2 version to Thingworx 8?
smohideen-2
supandey
(To:smohideen-2)
Hi Shaik, are you referring to the Import/Export Utility from the composer? It should be possible - what sort of entities are you importing? Are you running into an error/issue?
mnalla
7-Bedrock
(To:supandey)
Hi ,
I am facing the same issue but a different case. Like, I upgraded thingworx _8.0 to 8.1. I have a extension developed on eclipse. Which is working fine inside the thingworx_8.0. When i try to import the same extension into thingworx_8.1 . ptc-windchill-demo-thing present inside this thingworx_8.1 is not running.
with the following error:
2018-03-27 12:47:51.852+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: https-jsse-nio-443-exec-29] [context: com.thingworx.webservices.context.HttpExecutionContext@24434000][message: Thing [ptc-windchill-demo-thing] is not running]
madhu
