Hi When i save thing, property value disappear
CHASEONHO
18-Opal
Hi i'm SeonHo
i created thing using MQTT extensions
it was good working
when i pub, thingworx get sub
but i In spite of checked persistent
after click Save, property value go disappear
why? any suggestion for me?
thanks
AnnaAn
(To:CHASEONHO)
seonho Cha​,
It's like what in the errors: Not authorized for PropertyRead on temp in TestMqttThingLocalhost
You may need to give Run time permission for Property Read for the login user of Thing TestMqttThingLocalhost.
Br,
Anna
AnnaAn
(To:CHASEONHO)
seonho Cha​,
How will it be if you change persistent and save in the New Composer?
Br,
Anna
Actually, I solved it. just now
i don't know how i solved this
guess it is after click cancle edit.
thanks
AnnaAn
(To:CHASEONHO)
Glad to hear that.
Please let us know if it happens again.
There is an known similar issue for Kepware connection to ThingWorx; it's probably fixed in ThingWorx 8.1.0.
Anna
Ha...
another issue came to me
i was login as admin
i created a subscript of datachange which parseFloat
because mqtt data fomat is string
but error when datachange
Execution error in service script [TestMqttThingLocalhost temp.DataChange] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Not authorized for PropertyRead on temp in TestMqttThingLocalhost Cause: Not authorized for PropertyRead on temp in TestMqttThingLocalhost
it was still error after permission runtime, designtime
thanks
AnnaAn
(To:CHASEONHO)
seonho Cha​,
Br,
Anna
